[GRASS5] Buffer width.
Mon Nov 29 17:58:44 EST 2004
> I would like to know if it is possible to set buffer width (v.buffer)
> based on attributes stored in database file (GRASS 5.7).  So far I
> have set buffer width as a constant value or values.
run v.buffer buffer=$SIZE + v.patch in a shell loop, or:
d.vect.chart ctype=pie
on a single column of data (ie the size).
Hamish
