[GRASS5] [bug #2723] (grass) configure error with freetype option
Mon Nov 29 20:59:46 EST 2004
> Subject: configure error with freetype option
> CFLAGS="-g -Wall" ./configure --enable-shared --with-blas
> --with-lapack --with-freetype=/usr/lib --with-gdal=/usr/local/bin
> checking for location of LAPACK library...
> checking for dgesv_ in -llapack... yes
> checking whether to use Motif... no
> checking whether to use GLw... no
> checking whether to use FreeType... /usr/lib
> configure: error: *** You must answer yes or no.
You are using --with-freetype wrong. It is a true/false option and you
have given it a directory name. Try just:
--with-freetype
or with
--with-freetype-includes=/usr/include/freetype2
--with-freetype-libs= ...
same with --with-gdal.
see './configure --help | less' for help.
Hamish
