[GRASS5] grass51/debian/rules
Markus Neteler neteler at itc.it
Tue Nov 30 07:16:14 EST 2004
On Tue, Nov 30, 2004 at 05:51:55PM +1300, Hamish wrote:
> re this change:
> http://grass.itc.it/pipermail/grass-commit/2004-November/015869.html
> -		--with-gdal=/usr/bin/gdal-config \
> +		--with-gdal=/usr/local/bin/gdal-config \
> $ dpkg -L libgdal1-dev | grep gdal-config
> /usr/share/man/man1/gdal-config.1.gz
> ??? shouldn't it just be --with-gdal? Isn't that redundant now, omit
> altogether?
> +		--without-odbc
> The unixodbc-dev package is in the control file's "Build-Depends" list,
> why not use it?
Hamish,
please apply fixes right away since you have a Debian distro running.
Thanks
 Markus
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
