[GRASS5] [bug #2645] (grass) nad2bin.c:8:22: projects.h: No such file or directory
Request Tracker grass-bugs at intevation.de
Sat Oct 2 13:15:07 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2645
Subject: nad2bin.c:8:22: projects.h: No such file or directory
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
 OBJ.i686-pc-linux-gnu/get_proj.o OBJ.i686-pc-linux-gnu/do_proj.o OBJ.i686-pc-linux-gnu/convert.o OBJ.i686-pc-linux-gnu/datum.o OBJ.i686-pc-linux-gnu/ellipse.o -lgrass_gis -lgrass_datetime -lz    -L/usr/local/proj4/lib/ -lproj  -L/usr/local/gdal/lib -lgdal -o /home/slickenside/GRASS-GIS/grass-5.7.0/dist.i686-pc-linux-gnu/lib/libgrass_gproj.so
gcc -I/home/slickenside/GRASS-GIS/grass-5.7.0/include -I/home/slickenside/GRASS-GIS/grass-5.7.0/dist.i686-pc-linux-gnu/include -g -O2  -Wall -Wconversion -Wno-implicit-int   -fPIC  -rdynamic -L/home/slickenside/GRASS-GIS/grass-5.7.0/dist.i686-pc-linux-gnu/lib -L/usr/local/pgsql/lib/    nad2bin.c   -o nad2bin
nad2bin.c:12: warning: return type of `main' is not `int'
nad2bin.c: In function `main':
nad2bin.c:13: error: storage size of `ct' isn't known
nad2bin.c:14: error: `FLP' undeclared (first use in this function)
nad2bin.c:14: error: (Each undeclared identifier is reported only once
nad2bin.c:14: error: for each function it appears in.)
nad2bin.c:14: error: `p' undeclared (first use in this function)
nad2bin.c:14: error: `t' undeclared (first use in this function)
nad2bin.c:14: warning: left-hand operand of comma expression has no effect
nad2bin.c:24: error: `MAX_TAB_ID' undeclared (first use in this function)
nad2bin.c:27: error: parse error before ')' token
nad2bin.c:13: warning: unused variable `ct'
nad2bin.c:15: warning: unused variable `tsize'
nad2bin.c:16: warning: unused variable `i'
nad2bin.c:16: warning: unused variable `j'
nad2bin.c:16: warning: unused variable `ichk'
nad2bin.c:17: warning: unused variable `lam'
nad2bin.c:17: warning: unused variable `laml'
nad2bin.c:17: warning: unused variable `phi'
nad2bin.c:17: warning: unused variable `phil'
nad2bin.c:18: warning: unused variable `bin'
nad2bin.c: At top level:
nad2bin.c:32: error: parse error before '.' token
nad2bin.c:41: error: parse error before numeric constant
nad2bin.c:41: error: conflicting types for `exit'
/usr/include/stdlib.h:612: error: previous declaration of `exit'
nad2bin.c:41: warning: data definition has no type or storage class
nad2bin.c:45: error: parse error before '++' token
nad2bin.c:50: error: parse error before '++' token
nad2bin.c:55: error: parse error before numeric constant
nad2bin.c:55: warning: data definition has no type or storage class
nad2bin.c:59: error: parse error before numeric constant
nad2bin.c:59: warning: data definition has no type or storage class
nad2bin.c:64: error: parse error before numeric constant
nad2bin.c:64: warning: data definition has no type or storage class
nad2bin.c:66: error: parse error before numeric constant
nad2bin.c:66: warning: data definition has no type or storage class
make[2]: *** [nad2bin] Error 1
make[2]: Leaving directory `/home/slickenside/GRASS-GIS/grass-5.7.0/lib/proj'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory `/home/slickenside/GRASS-GIS/grass-5.7.0/lib'
make: *** [default] Error 1
linux:/home/slickenside/GRASS-GIS/grass-5.7.0 #
me used SuSE Linux 9.1 Professional ........
-------------------------------------------- Managed by Request Tracker
