[GRASS5] Re: [GRASSLIST:4463] Re: fixes for recent problems in tcltkgrass for GRASS 5.3
Michael Barton michael.barton at asu.edu
Mon Oct 4 17:30:15 EDT 2004
Thanks.
I can try this out and see if it does the trick. If so, I'll go ahead and
update.
Michael
On 10/4/04 1:56 PM, "Glynn Clements" <glynn.clements at virgin.net> wrote:
> It should probably be:
> set prog [lindex $cmd 0]
> set args [lrange $cmd 1 end]
> set name [eval concat $prog [list $args]]
> This will split the command but not the arguments.
______________________________
Michael Barton, Professor of Anthropology
School of Human Diversity and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
