[GRASS5] Let's release 5.4 asap
Bernhard Reiter
bernhard at intevation.de
Fri Oct 8 06:37:37 EDT 2004
On Mon, Oct 04, 2004 at 10:47:31AM +0200, Markus Neteler wrote:
> On Fri, Oct 01, 2004 at 01:32:03PM +0200, Bernhard Reiter wrote:
> > got you wrong on that point then.
> > Moving it into the old section is of course fine.
> > (Though currently the links to the old section make
> > you search a bit until you find it again... )
> ... which is good to avoid that "normal" users grab the old
> stuff (and then complain). If a software engineer wants to
> study the development history of GRASS, they'll be able to
> find it :-)
I tend to disagree, because this has a mental model
or "normal" users that I do not share.
A clear marking should be fine and adaquate for a good archive.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041008/5236b64e/attachment.bin
