[GRASS5] Re: grass57 and 3D import
Radim Blazek blazek at itc.it
Mon Oct 11 06:04:02 EDT 2004
On Thursday 07 October 2004 15:14, Markus Neteler wrote:
> Yes, I guess that you didn't specify the column type when using
> v.in.ascii (see my example above how to do that). By default it will
> make every type in the DB a string as it cannot guess the column type.
No, it _guess_ the column type, whole input is read first, to find
the column type.
Radim
