[GRASS5] [bug #2662] (grass) 5.7 debianization : libtiff3g-dev is no longer availalable in debian/sid
Request Tracker
grass-bugs at intevation.de
Thu Oct 14 06:36:44 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2662
Subject: 5.7 debianization : libtiff3g-dev is no longer availalable in debian/sid
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Compiled from Sources
GRASS Version: 5.7.0
Hello,
I'd downloaded the 5.7 sources from
http://grass.ibiblio.org/grass57/source/
[The source package is time-stamped, there "17-Jun-2004"]
It was great to see that there's already a 'debian' directory in the
unpacked GRASS 5.7 sources.
I tried to 'debuild' 5.7, then (using debian/sid, locally).
The debian 'control' file for 5.7 includes a build-dependency on
libtiff3g-dev
It appears that there is no longer a libtiff3g-dev in debian/sid
As an attempt at a workaround, I've adjusted the "libtiff3g-dev" build
dependency, locally, to be "libtiff3g-dev| libtiff4-dev"; I'm not entirely
sure if it'll build, now, but I'm certainly hopeful
Thank you
Sean Champ
-------------------------------------------- Managed by Request Tracker
