[GRASS5] v.voronoi fails to build
Markus Neteler
neteler at itc.it
Thu Oct 14 07:24:29 EDT 2004
On Thu, Oct 14, 2004 at 05:49:57PM +1300, Hamish wrote:
> The new v.voronoi fails to build,
> "libgrasss_raster.so not found, needed by libgrass_display.so"
> libgrass_display.so: undefined reference to `R_pad_delete'
On RH7/RH9/MDK10 no problem. Which OS/platform are you refering to?
v.voronoi ismaa_centraline out=voronoi
Building topology ...
49 areas built %
1 isles built
Topology was built.
Number of nodes : 151
Number of primitives: 201
Number of points : 0
Number of lines : 0
Number of boundaries: 150
Number of centroids : 51
Number of areas : 49
Number of isles : 1
Number of incorrect boundaries : 2
Number of duplicate centroids : 2
^^^^^^ bug or feature?
Probably some input points are directly on the border?
Markus
