[GRASS5] Problems with UTM/southern hemisphere
Markus Neteler neteler at itc.it
Thu Oct 14 10:15:07 EDT 2004
a colleague of mine from Argentina is facing problems
to import LANDSAT data in UTM.
Displaying a map leads to:
GRASS 5.7.cvs > d.rast markus.1
WARNING: [markus.1] in mapset [beinlich] - in different zone [20] than
         current region [-20]
WARNING: unable to open raster map [markus.1 in beinlich]
ERROR: Not able to open cellfile for [markus.1]
The location is defined as (UTM, southern hemisphere):
GRASS 5.7.cvs > cat WIND
proj:       1
zone:       -20
north:      6422700
south:      6285990
east:       5509920
west:       5368500
cols:       4714
rows:       4557
e-w resol:  30
n-s resol:  30
Mapset <beinlich> in Location <rosarioutm>
Looking at the map header:
GRASS 5.7.cvs > cd cellhd/
GRASS 5.7.cvs > cat markus.1
proj:       1
zone:       20                     <-- shouldn't this be -20?
north:      6362801.5
south:      6341626
east:       726550.5
west:       703978.5
cols:       792
rows:       743
e-w resol:  28.5
n-s resol:  28.5
format:     0
compressed: 1
GRASS 5.7.cvs > g.proj -p
-PROJ_INFO-------------------------------------------------
datum      : wgs84
towgs84    : 0.000,0.000,0.000
proj       : utm
ellps      : wgs84
a          : 6378137.0000000000
es         : 0.0066943800
f          : 298.2572235630
zone       : 20                            <- positive, but
south      : defined                       <- southern hemisphere indication
-PROJ_UNITS------------------------------------------------
unit       : meter
units      : meters
meters     : 1.0
GRASS 5.7.cvs > g.proj -w
PROJCS["UTM Zone 20, Southern Hemisphere",
    GEOGCS["wgs84",
        DATUM["WGS_1984",
            SPHEROID["wgs84",6378137,298.257223563],
            TOWGS84[0.000,0.000,0.000]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-63],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",10000000],
    UNIT["meter",1]]
May it be possible that G_get_projinfo() doesn't understand
well that 'south' is defined?
Mhh, probably I have to debug a bit.
Markus
