[GRASS5] LatLong E/W problem in southern hemisphere
Roger Bivand
Roger.Bivand at nhh.no
Fri Oct 15 13:14:57 EDT 2004
On Fri, 15 Oct 2004, Markus Neteler wrote:
> > > > > Hi,
> > > > > we have a map in LatLong, located somewhere in Argentina:
> > > > > g.region rast=noaa -p
> > > > > projection: 3 (Latitude-Longitude)
> > > > > zone: 0
> > > > > datum: wgs84
> > > > > ellipsoid: a=6378137 es=0.00669438
> > > > > north: 30:24S
> > > > > south: 35:42:00.0036S
> > > > > west: 58:17:59.9964W
> > > > > east: 65:11:59.9892W <- note this correct value
> > > > Just asking: does Southern hemisphere mean we look at things upside down?
> > > > Shouldn't east be (yes) east of west, this east is almost 7 degrees west
> > > > of west, and I think the algorithm is (logically) assuming that you want
> > > > what is asked for, 353 degrees? Or am I missing something (I wouldn't be
> > > > surprised!)? Maybe a warning could be useful when the nsres/ewres ratio is
> > > > so extreme?
> > > Roger, the problem (to me) is that above we have the expected value
> > > 65:11:59.9892W, which becomes later 294.800003
> > > (360 - 294.800003 = 65.2 !). So the wrap around doesn't work (or whatever).
> > Why is the declared east west of west? Isn't the program just doing what
> > it was asked to do? It seems to say that, well, if the stated east is west
> > of west *in lat-long* this can be resolved by going round the other way,
> > which it then does. Isn't this an input error?
> > east=-65.199997 west=-58.299999
> > west= east=
> > seems more likely? I don't think it's the code, I think it's doing what it
> > was told?
> Roger,
> let's see it from a user's perspective (my colleague):
> He fetched the NOAA image from the web, file in plain binary
> format. The metadata told him how to select the parameters
> for r.in.bin.
> First he mixed east and west and it gave *no* error (while it
> does in case of north/south confusion). This delivered a messy
> map. Eventually I found out that he mixed east/west, changing
> that the map was imported correctly. But of course I was
> wondering why r.in.bin didn't complain.
> You may be right that the behaviour is correct. But in fact
> not helpful for this particular case. I darkly remember that
> this was discussed once here, but don't recall details.
> It was probably the same trap of 'how to go around the globe...'.
> But shouldn't this then raise alarm due to a wrong number
> of columns? Ah, in fact the resolution was wrong then. So
> it's the way how r.in.bin determines rows/cols/resolution.
> Now it seems clear to me: no bug, but unfortunate case.
Right - I think a warning when the ratio of resolutions seems extreme
might be justified, or a note on the manpage to check the ewres for
sanity. With a projected data set, the E > W test would have worked.
Roger
> Markus
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
