[GRASS5] [bug #2668] (grass) r.statistics G_calloc: out of memory
Request Tracker
grass-bugs at intevation.de
Tue Oct 19 16:04:43 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2668
Subject: r.statistics G_calloc: out of memory
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Compiled from Sources
GRASS Version: grass53_exp_2004_08_21
r.statistics base=topo_09780646 cover=topo_09780648 method=sum output=sum
r.stats: 100%
ERROR: G_calloc: out of memory
the region and rasters info (negative values because it's a S-JTSK Krovak East North projection, epsg <102067>):
GRASS:~ > g.region -p
projection: 0 (x,y)
zone: 0
north: -977855.55000002
south: -980104.72000002
west: -650068.55000007
east: -645725.15000007
nsres: 1.27
ewres: 1.27
rows: 1771
cols: 3420
GRASS:~ > r.info topo_09780648
| Layer: topo_09780648 Date: Mon Oct 18 21:00:30 2004 |
| Mapset: PERMANENT Login of Creator: ziutek |
| DataBase: /home/grassdata |
| Title: ( topo_09780648 ) |
| Type of Map: raster Number of Categories: 5 |
| Data Type: CELL |
| Rows: 1575 |
| Columns: 1575 |
| Total Cells: 2480625 |
| Projection: x,y (zone 0) |
| N: -977999.365 S: -979999.615 Res: 1.27 |
| E: -648000.385 W: -650000.635 Res: 1.27 |
| Range of data: min = 0 max = 5 |
| Data Source: |
| Data Description: |
| generated by r.in.gdal |
GRASS:~ > r.info topo_09780646
| Layer: topo_09780646 Date: Mon Oct 18 20:59:46 2004 |
| Title: ( topo_09780646 ) |
| Data Type: CELL |
| Rows: 1575 |
| Columns: 1575 |
| E: -646000.385 W: -648000.635 Res: 1.27 |
| Data Source: |
| Data Description: |
Maciek Sieczka
-------------------------------------------- Managed by Request Tracker
