[GRASS5] Re: [GRASS-CVS] hamish: grass/html/html
r.out.mpeg.html,1.4,1.5
Hamish
hamish_nospam at yahoo.com
Fri Oct 22 00:52:18 EDT 2004
> GRASS 5.7.cvs:/tmp > r.out.mpeg -c view1=`g.mlist type=rast
> pat="modis_lst1km2004*.LST_Day_1km.filt" sep=,` out=gmovie_with_c.mpg
Note you shouldn't need `g.mlist`, r.out.mpeg knows about ('quoted')
wildcards.
Also note that before two days ago g.mlist mixed filename order.
> MPEG ENCODER STATS (1.5b)
> TIME STARTED: Wed Oct 20 17:42:43 2004
> MACHINE: unknown
> FIRST FILE: in=/modis_lst1km20040101.LST_Day_1km.filt
> LAST FILE: in=/modis_lst1km20040727.LST_Day_1km.filt
> PATTERN: ibbpbb
> GOP_SIZE: 30
> SLICES PER FRAME: 1
> RANGE: +/-8
> PIXEL SEARCH: HALF
> PSEARCH: TWOLEVEL
> BSEARCH: CROSS2
> QSCALE: 7 12 16
> REFERENCE FRAME: DECODED
> ERROR: Couldn't execute input conversion command:
> r.out.ppm -q in=/modis_lst1km20040101.LST_Day_1km.filt out=-
> errno = 22
> SLAVE EXITING!!!
> WARNING: mpeg_encode ERROR
> The slash is wrong (today I have no time to search for it in the
> code).
I'm not sure.
I'll try and build mpeg_encode 1.5b, maybe the bug is there?.
Hamish
