[GRASS5] [bug #2674] (grass) configure problem with odbc and iconv
Request Tracker
grass-bugs at intevation.de
Fri Oct 22 16:35:18 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2674
Subject: configure problem with odbc and iconv
Platform: WindowsNT/2000/XP
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 5.7.0
I failed to configure ODBC library due to the lack of -liconv flag. On cygwin, iconv is a separate library, so -liconv should be specified for ODBC library which requires iconv. I tried to modify configure.in without success; autoconf takes forever! So I'm reporting here.
Thanks
-------------------------------------------- Managed by Request Tracker
