[GRASS5] ogsf and nvis compile errors
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Oct 25 14:20:02 EDT 2004
On Mon, 25 Oct 2004, Helena wrote:
> Kirk,
> I have just added the volume support for nviz - you need to run make mixclean
> before compiling. If you still get the error, check whether you
Just to confirm---make mixclean should be run before updating from CVS
(otherwise some of the new NVIZ files in 5.7 will not check out). See the
INSTALL file.
