[GRASS5] D.vect.graph problem
Wed Sep 1 02:08:47 EDT 2004
> I did what you suggested. When I run d.vect.chart using bar graphs,
> the process (along with a dbf process) very briefly flashes in top
> then disappears as it finishes.
what does the data look like?
i.e. **how many points in the data file**, what kind of data (integer,
floating point, etc)?
Can you try it with a different points file?
Vect_destroy_line_struct() is called to free the memory put aside for
each polygon as they draw....
Hamish
