[GRASS5] [bug #2597] (grass) Some binary files not cleaned
Request Tracker
grass-bugs at intevation.de
Wed Sep 1 10:18:31 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2597
Subject: Some binary files not cleaned
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 5.7.0
While trying to package grass for Debian I get the following errors. Basically this means these files are not removed by 'make distclean'.
pkg-source: cannot represent change to lib/proj/nad2bin: binary file contents changed
dpkg-source: cannot represent change to tools/timer/main.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/ply_t_bmif.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/yadjust.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/bmf_to_cll.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/save_area.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/wrte_recrd.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/do_dots.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/find_area.o: binary file contents changed
dpkg-source: cannot represent change to raster/r.le/r.le.setup/polytocell/do_line.o: binary file contents changed
Thanks,
Steve Halasz
-------------------------------------------- Managed by Request Tracker
