[GRASS5] 5.7: dbf driver and 'double' initialization
Markus Neteler
neteler at itc.it
Mon Sep 6 23:54:50 EDT 2004
Hi Gordon,
(cc grass5)
generally I agree, but:
echo "UPDATE dourokukan SET forward=50 WHERE forward is null" | db.execute
DBMI-DBF driver error:
SQL parser error in statement:
Error in db_execute_immediate()
WARNING: Error while executing: "UPDATE dourokukan SET forward=50 WHERE
forward is null
The problem for me is "how to tell GRASS?"...
Regards
Markus
On Tue, Sep 07, 2004 at 01:44:54PM +1000, Gordon Keith wrote:
> Knowing nothing about dbf in grass, but a bit about SQL, the behaviour
> indicated would seem to me to be absolutely correct.
> The SQL update (assuming normal SQL rules) you want would be:
> NULL and zero are very different values.
> Regards
> Gordon
> On Tue, 7 Sep 2004 12:55, Markus Neteler wrote:
> > There seems to be a problem with the initialization of
> > double (maybe also int) type in the DBF driver of 5.7:
> > echo "ALTER TABLE dourokukan ADD COLUMN forward double" | db.execute
> > echo "ALTER TABLE dourokukan ADD COLUMN backward double" | db.execute
> > echo "ALTER TABLE dourokukan ADD COLUMN length double" | db.execute
> > dbfdump dourokukan.dbf
> > cat label forward backward length
> > 1 s3m (NULL) (NULL) (NULL)
> > 3 e3.0m (NULL) (NULL) (NULL)
> > 5 e5.5m (NULL) (NULL) (NULL)
> > 13 s13.0 (NULL) (NULL) (NULL)
> > 15 yes (NULL) (NULL) (NULL)
> > I assume that it should be set to zero (0).
> > At least I don't know how to access these (NULL) values in
> > a later SQL update :
> > echo "UPDATE dourokukan SET forward=50 WHERE forward=0" | db.execute
> > echo "SELECT * FROM dourokukan" | db.select
> > cat|label|forward|backward|length
> > 1|s3m|||
> > 3|e3.0m|||
> > 5|e5.5m|||
> > 13|s13.0|||
> > 15|yes|||
> > Any advice is welcome,
> > Markus
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> Gordon Keith
> Programmer/Data Analyst
> Marine Acoustics
> CSIRO Marine Research
> http://www.marine.csiro.au
> "Computers in the future may weigh no more than than 1.5 tons."
> - Popular Mechanics, 1949
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
