[GRASS5] 5.7: dbf driver and 'double' initialization
Glynn Clements
glynn.clements at virgin.net
Wed Sep 8 03:47:26 EDT 2004
Markus Neteler wrote:
> thanks for the patch. A minor thing might be missing:
> echo "UPDATE dourokukan SET testc=50 WHERE testc is NULL" | db.execute
> DBMI-DBF driver error:
> Unknown operator 18
Right; there are two switch statements which examine the operator. I
extended the one in eval_node(), but missed the one in
eval_node_type(). Try the attached patch.
Glynn Clements <glynn.clements at virgin.net>
--- db/drivers/dbf/dbfexe.c~ Tue Sep 7 08:42:06 2004
+++ db/drivers/dbf/dbfexe.c Wed Sep 8 08:44:23 2004
@@ -896,6 +896,10 @@
return SQLP_BOOL;
+ case SQLP_ISNULL:
+ case SQLP_NOTNULL:
+ return SQLP_BOOL;
/* Logical */
case SQLP_AND:
if ( left == SQLP_NULL || right == SQLP_NULL ) {
