[GRASS5] D.vect.graph problem
Glynn Clements
glynn.clements at virgin.net
Tue Sep 21 14:03:23 EDT 2004
Michael Barton wrote:
> Indeed, there are some cases for which all columns used in the pie chart
> would be zero. Do I need to filter these out? Perhaps the pie chart
> algorithm should automatically filter these out if it is problematic??
The algorithm needs to iterate for a fixed number of steps. Try the
attached patch.
Glynn Clements <glynn.clements at virgin.net>
--- pie.c~ Sun Sep 5 08:20:31 2004
+++ pie.c Tue Sep 21 18:58:25 2004
@@ -11,7 +11,7 @@
int
pie ( double cx, double cy, int size, double *val, int ncols, COLOR *ocolor, COLOR *colors )
- int i, j;
+ int i, j, n;
double a, end_ang, ang, tot_sum, sum, step, r;
double x, y;
struct line_pnts *Points;
@@ -36,20 +36,15 @@
if (val[0] != tot_sum) /* all in one slice, don't draw line to center */
Vect_append_point ( Points, cx, cy, 0);
- a = ang;
- while ( 1 ) {
+ n = (int)ceil((end_ang - ang) / step);
+ for (j = 0, a = ang; j <= n; j++, a += step)
if ( a > end_ang ) a = end_ang;
x = cx + r * cos ( a );
y = cy + r * sin ( a );
Vect_append_point ( Points, x, y, 0);
- if ( a == end_ang ) {
- ang = end_ang;
- break;
- } else {
- a += step;
+ ang = end_ang;
