[GRASS5] howto: direct access to raster cells - skeletons in cvs?
Stefan Paulick
stefan.paulick at urbeli.com
Tue Sep 28 13:08:21 EDT 2004
I want to perform the following task:
1) read a single cell in a raster map
2) modify its value
3) write it back and display the map
When having a look at r.example using KDevelop, I received
module = G_define_module();
-> warning: assignment makes pointer from integer without a cast
and
module->description ="GRASS raster programming example.";
-> error: dereferencing pointer to incomplete type
so I got both stuck and very nervous... ;-))
It would be very helpful if there were some basic skeletons ( r.user, v.user
...) prepared in the cvs for home-brewed functions which do compile clean
and are showing the correct use of the given basic resources.
Mit freundlichen Grüßen / With kindest regards
Stefan Paulick
http://www.urbeli.com
