[GRASS5] Endian tests
Glynn Clements
glynn at gclements.plus.com
Sun Apr 3 23:38:30 EDT 2005
Hamish wrote:
> lib/gis/endian.c uses:
> int G_is_little_endian (void)
> union
> int testWord;
> char testByte[4];
> } endianTest;
> int swapFlag;
> endianTest.testWord = 1;
> if (endianTest.testByte[0] == 1)
> swapFlag = 1; /*true: little endian */
> else
> swapFlag = 0; /* false: big endian */
> return swapFlag;
> should that be:
> - char testByte[4];
> + char testByte[sizeof(int)];
Probably, although ideally it should be a compile-time test, e.g.
<endian.h>.
