[GRASS5] Problem converting NAD27 to NAD83 - missing ntv1_can.dat
Glynn Clements
glynn at gclements.plus.com
Fri Apr 8 23:39:35 EDT 2005
Craig Funk wrote:
> It ends up that the ntv1_can.dat file did not appear to be installed
> properly. Where should the file live? I placed it in etc/nad directory
> of the GRASS installation and then the r.proj and v.proj commands
> worked fine.
> I built my GRASS install from source on a Mac G5. Is this maybe a
> problem with the makefiles?
That file should be installed into etc/nad by lib/proj/Makefile. Check
the output from "make -C lib/proj" in case there is an error which
prevents it from being installed.
