[GRASS5] r.in.gdal - precision problem in lib/gis/adj_cellhd.c
Tue Apr 12 02:37:17 EDT 2005
On Mon, 11 Apr 2005 17:05:57 +0200
Markus Neteler <neteler at itc.it> wrote:
> However, in this case it was r.in.gdal which caused problems:
>  http://grass.itc.it/pipermail/grass5/2005-April/017946.html
>  "r.in.gdal SRTM_GTOPO_u30_n090w020.tif out=srtm90_gtopo30
>   D0/0: North: 90.0000000002
>   WARNING: G_set_window(): Illegal latitude for North
> Would be nice to accept such subtle deviations as shown above.
> Corner Coordinates:
> Upper Left    ( 20d 0' 0.00"W, 90d 0' 0.00"N)
Note that is 22e-06 meters. We can make the test 0.1mm above 90deg lat,
0.0001 / (60*1852.) = 8.9993e-10
but will doing this allow weird segfaults with e.g. *.proj etc. down the
road? I think it might; better to fix the GDAL casting?
Hamish
