[GRASS5] [bug #3153] (grass) v.in.garmin waypoint import
Hamish
hamish_nospam at yahoo.com
Tue Apr 12 05:00:49 EDT 2005
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3153
> Subject: v.in.garmin waypoint import
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: 6.0 release
> The waypoint-import works fine for LL-locations.
> If a UTM-location is used, there's a problem about the database:
> v.in.garmin -v -w out=tafelnX port=/dev/ttyS0
> ---------snip----------------------------------
> Uploading Waypoints
> Coordinate format: DDD
> Attempting waypoint projection transform with cs2cs
> Importing Waypoints...
> Maximum input row length: 0
> Maximum number of columns: 0
> Minimum number of columns: -1
> ERROR: x column number > minimum last column number
> <tafelnX> columns:
> DBMI-DBF driver error:
> Table 'tafelnX' doesn't exist
> Done.
can you try without setting the output= option? then it will send
data to stdout and you can see why v.in.ascii is unhappy.
doesn't look like any data is getting there.
You might try commenting out the "rm" line at the end of the file and
then looking at the bits left over in $MAPSET/.tmp/$HOST/ to see how
far the data makes it.
note: known bug (unreleated), db link must be set with db.connect
before using the module; if DBF, then a $MAPSET/dbf/ dir must exist
too? [haven't tested in a while]
Hamish
