[GRASS5] [bug #3160] (grass) r.support build error
Request Tracker grass-bugs at intevation.de
Mon Apr 18 18:05:16 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3160
Subject: r.support build error
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: cvs_18_04_05
GRASS GIS compilation log
Started compilation: pon kwi 18 21:16:20 CEST 2005
Errors in:
/home/pingwin/src/grass6/raster/r.support/modcats
/home/pingwin/src/grass6/raster/r.support/modhist
Finished compilation: pon kwi 18 21:26:31 CEST 2005
(In case of errors please change into the directory with error and run 'make')
   So I did:
[pingwin at localhost r.support]$ make
modcats
make[1]: Entering directory `/home/pingwin/src/grass6/raster/r.support/modcats'
Makefile:15: ostrze¿enie: polecenia zakrywaj±ce dla obiektu `htmletc1'
../../../include/Make/Rules.make:94: ostrze¿enie: ignorujê stare polecenia dla obiektu `htmletc1'
gcc -s -pipe -D_FILE_OFFSET_BITS=64 -Wl,--export-dynamic -L/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib        -DPACKAGE=\""grassmods"\" -o /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcats OBJ.i686-pc-linux-gnu/modcats.o -lgrass_gis -lgrass_datetime -lz    -lgrass_edit -lm  -lz
/usr/bin/ld: warning: libgrass_vask.so, needed by /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so, not found (try using -rpath or -rpath-link)
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so: undefined reference to `V_ques'
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so: undefined reference to `V_line'
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so: undefined reference to `V_call'
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so: undefined reference to `V_intrpt_ok'
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so: undefined reference to `V_const'
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so: undefined reference to `V_clear'
collect2: ld returned 1 exit status
make[1]: *** [/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcats] B³±d 1
make[1]: Leaving directory `/home/pingwin/src/grass6/raster/r.support/modcats'
modcolr
make[1]: Entering directory `/home/pingwin/src/grass6/raster/r.support/modcolr'
No docs to generate.
echo "<HR>" >> modcolr.tmp.html
#generate module class reference:
echo "</body></html>" >> modcolr.tmp.html
mkdir -p /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html
mv -f modcolr.tmp.html /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html/modcolr.html
/usr/bin/install -c  *.png *.jpg /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html 2> /dev/null ; true
mkdir -p /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/support
/usr/bin/install -c  -m 755 /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcolr /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/support
make[1]: Leaving directory `/home/pingwin/src/grass6/raster/r.support/modcolr'
modhist
make[1]: Entering directory `/home/pingwin/src/grass6/raster/r.support/modhist'
Makefile:15: ostrze¿enie: polecenia zakrywaj&#177;ce dla obiektu `htmletc1'
gcc -s -pipe -D_FILE_OFFSET_BITS=64 -Wl,--export-dynamic -L/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib        -DPACKAGE=\""grassmods"\" -o /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modhist OBJ.i686-pc-linux-gnu/modhist.o -lgrass_gis -lgrass_datetime -lz    -lgrass_edit -lm  -lz
make[1]: *** [/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modhist] B³&#177;d 1
make[1]: Leaving directory `/home/pingwin/src/grass6/raster/r.support/modhist'
modhead
make[1]: Entering directory `/home/pingwin/src/grass6/raster/r.support/modhead'
echo "<HR>" >> modhead.tmp.html
echo "</body></html>" >> modhead.tmp.html
mv -f modhead.tmp.html /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html/modhead.html
/usr/bin/install -c  -m 755 /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modhead /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/support
make[1]: Leaving directory `/home/pingwin/src/grass6/raster/r.support/modhead'
front
make[1]: Entering directory `/home/pingwin/src/grass6/raster/r.support/front'
GISRC=/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/demolocation/.grassrc61 GISBASE=/home/pingwin/src/grass6/dist.i686-pc-linux-gnu PATH=/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/bin:$PATH LD_LIBRARY_PATH="/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib:" /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/bin/r.support --html-description | grep -v '</body>' > r.support.tmp.html ; true
echo "<HR>" >> r.support.tmp.html
echo "</body></html>" >> r.support.tmp.html
mv -f r.support.tmp.html /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html/r.support.html
make[1]: Leaving directory `/home/pingwin/src/grass6/raster/r.support/front'
gcc 3.4.1 if it matters
Maciek
-------------------------------------------- Managed by Request Tracker
