[GRASS5] doxygen
J.C.M. van der Kwast
jkwast at freeler.nl
Tue Apr 19 15:32:09 EDT 2005
Hi list,
Allmost a year ago we were discussing the doxygen generated output. I've
finally finished a script which puts eveything in it's own directory and
is fully linked against each other.
As you were the only one, ever to express any interest, I'm hopefully
not bothering you too much.
To make it easy for you I've put the main directories
$grass_sources/include and $grass_sources/lib on my webspace here:
members.home.nl/jkwast/doxygenhtml
I forgot to run ./configure before running the scripts, so some links
are not made but will when you run configure first (things like in
config.h). Also in some cases there are double names for structs,
unions, functions etc. that doxygen cannot handle proper. I will, to
that purpose, finish another script in a couple of days to make lists of
those so we can remedy that easily.
If you like it, I can send you the scripts and related files for
reviewing and maybe uploading to cvs.
Greetings,
Bsc. Tropical Agriculture
