[GRASS5] [bug #3164] (grass) Zoom in v.digit
Tue Apr 19 20:28:35 EDT 2005
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3164
> Using Zoom in the v.digit utility is pretty unreliable.
There is room for improvement, yes.
(starting with reset to original region on exit)
> After using the zoom in and zoom out option in v.digit, the program
> usually stops working.
can you provide more details on what "stops working" means? How far
in/out did you zoom? What projection? when? error messages? lockup?
Hamish
