[GRASS5] [bug #3166] (grass) bad target region calculations with i.rectify order=3
Request Tracker grass-bugs at intevation.de
Wed Apr 20 01:00:11 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3166
Subject: bad target region calculations with i.rectify order=3
i.rectify (both 6.0.0, 6.1cvs) is creating rasters with incorrect regions and
resolutions when doing a 3rd order transform. It works fine with 1st or second
order transforms. 'i.rectify -c' (or lower order) is needed to get a good
transform.
Starting with unreferenced simple XY map (PNG imported with r.in.gdal)
and re-regioned to positive values with r.region, keeping res=1 pixel.
Target location is lat/lon (both wgs84 and none/intl datums fail)
e.g. eastern boundary ends up being +2 degrees east of what it should be,
resolution is calculated from e-w/cols so that ends up very coarse...
southern boundary is wrong too.
CRS_georef() in imagery/i.rectify/crs.c ?
more info available upon request.
thanks,
Hamish
-------------------------------------------- Managed by Request Tracker
