[GRASS5] [bug #3180] (grass) Re: [GRASSLIST:6578] Who wants contour lines labeled "300.000000"?
Request Tracker grass-bugs at intevation.de
Sat Apr 23 17:50:55 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3180
In "[GRASSLIST:6578] Who wants contour lines labeled "300.000000"?",
Jacobson discusses some points that may very well be actual bugs...
If I was using obsolete commands, that is because they should have been removed
but weren't.
PS, when we arrive at
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassSixTutorial
we find it is really only a VectorTutorial
therefore, it should be a subpage of GrassSixTutorial.
P.S., I am carefully digitizing a line in v.digit, and I need
to pan down further.  I click the pan button, and all my points
become lost.  There is no consideration for people who need to
shift the view during line entry.  And no warning that work will be
lost.
So I will have to use two lines.
And it looks like I'll have to join the lines outside of v.digit, as all one
can do there is add only 1 point to older lines.
So one must use v.build.polylines.
P.S., no error here:
$ g.remove non_existant;echo $?
0
It should act like rm(1) and cause an error.
Actually we didn't say vect=, rast= here. Still, raise an error.
file:///usr/lib/grass/docs/html/v.to.db.html links to v.category, not v.category.html.
Same problem on v.category.html.
Use a linkchecker.
In v.segment.html, say if offset and side offset mean X and Y or what.
In v.select documentation, say how to select the point at the intersection of two lines.
The line in map 1 is north south.
The line in map 2 is EW.
--- Headers Follow ---
>From jidanni at jidanni.org  Sat Apr 23 23:50:55 2005
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id 3436C1005C9
	for <grass-bugs at lists.intevation.de>; Sat, 23 Apr 2005 23:50:55 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
	by mail.intevation.de (Postfix) with ESMTP id F3D8C36CDC
	for <grass-bugs at lists.intevation.de>; Sat, 23 Apr 2005 23:50:54 +0200 (CEST)
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
	by mail.intevation.de (Postfix) with ESMTP id 3524C36CDB
	for <grass-bugs at intevation.de>; Sat, 23 Apr 2005 23:50:54 +0200 (CEST)
Received: from tc218-187-64-171.2-1.dynamic.apol.com.tw ([218.187.64.171]:33333 helo=jidanni1)
	by frodo.hserus.net with esmtpsa
	(Cipher TLSv1:AES256-SHA:256) (Exim 4.50 #1)
	id 1DPSWD-000AoS-SU by authid <jidanni> with plain
	for <grass-bugs at intevation.de>; Sun, 24 Apr 2005 03:20:52 +0530
To: grass-bugs at intevation.de
Subject: Re: [GRASSLIST:6578] Who wants contour lines labeled "300.000000"?
References: <8764yhf9bc.fsf at jidanni.org>
Date: Sat, 23 Apr 2005 07:32:29 +0800
Message-ID: <87u0lyo0aa.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.2 tagged_above=-999.0 required=3.0 tests=BAYES_00,
	DATE_IN_PAST_12_24
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
