[GRASS5] nviz and volumes
Bob Covill
bcovill at tekmap.ns.ca
Sun Apr 24 13:04:53 EDT 2005
Hi Helena, Jáchym,
I am away right now and cannot confirm this. But when I last tried the
Slovakia volume dataset, I had the same problem (i.e. no volumes displayed).
What I discovered wass that the 3D region (g.region) had to be set. Once the
3D region was set I was able to view the volume data.
I do not know if this is what is causing the problem.
Hope this helps.
Bob
On 4/24/2005, "Helena" <hmitaso at unity.ncsu.edu> wrote:
>Jachym Cepicky wrote:
>> Hallo developers,
>> I just tryed the 3D dataset of Slovakia, but I'm afraid, I can not
display
>> volumes by NVIZ.
>> I use GRASS 6.1 from 2005-04-19 od Debian Sarge.
>> Everything is set, like written in the README
>> file.
>> The screenshot can be found at http://www.fle.czu.cz/~jachym/.../nviz.png
>> What to do? I did not see any problems reported in the list...
>I just got the same problem reported by Bill Brown - let me try it out too.
>Helena
>> Thank you
>> Jáchym
>_______________________________________________
>grass5 mailing list
>grass5 at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grass5
