[GRASS5] dropping or renaming a column
Kirk R. Wythers
kwythers at umn.edu
Thu Apr 28 15:38:42 EDT 2005
On Apr 27, 2005, at 11:11 AM, Jachym Cepicky wrote:
> for adding columns to the table see manual of db.execute
> echo "alter table vector_file add column column_name
> varchar(50)"|db.execute
Thanks!
How about removing a column or changing a column name? I've tried:
> echo "ALTER TABLE table_name DROP COLUMN column_name double" |
db.execute
and
> echo "ALTER TABLE table_name CHANGE COLUMN old_column_name
new_column_name double" | db.execute
with no success...
Kirk
