[GRASS5] Re: Gem compiling error
benducke at compuserve.de benducke at compuserve.de
Sat Aug 6 09:42:43 EDT 2005
Thanks a lot for the report. I will look
into the cause of these warnings a little
later. Yes, r.cva eats up a lot of CPU
time but it is not really a memory hog.
It could be optimized but that would
require serious tweaking of the core
LOS code.
----- Originalnachricht -----
Von: Michael Barton <michael.barton at asu.edu>
Datum: Freitag, 29. Juli 2005 6:53 am
Betreff: Re: Gem compiling error
> Here is a report on r.cva.
> It looks to be a great tool. It seems to work pretty well, though
> it takes a
> surprising amount of time for it calculations. I've been running
> over 10
> minutes on my G4 Powerbook (1 GHz with 512 Mb RAM) with the Spearfish
> dataset doing a cumulative viewshed for 6 sites across the 30m dem.
> It gives a series of warnings as it works that I don't
> understand--especially the number of them given I'm only looking
> at 6 sites.
> (see below). It also eats up 60-90+% of my cpu resources, though
> it doesn't
> take a lot of RAM. I suppose it's doing a lot of swapping.
> One small bug. The browse button for elevation raster map only
> seems to show
> floating point maps. Basic integer maps are not seen, though it
> seems I can
> type them in.
> I hope this is helpful.
> Thanks again for doing this.
> Michael
> Anyway here's the output so far...
> r.cva input=elevation.dem sites=archsites_water100m
> output=cva_archsitesobs_elev=1.75 target_elev=0.0 max_dist=20000
> seed=1 sample=10.0 type=sites
> curvc=0.0 -f -o
> segment_pagein: No such file or directory
> GRASS_INFO_WARNING(11179,2): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,3): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,4): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,5): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,6): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,7): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,8): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,9): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,10): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,11): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,12): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,13): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,14): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,15): segment_pagein: Bad file descriptor
> GRASS_INFO_WARNING(11179,16): segment_pagein: Bad file descriptor
> [the progress bar is about half-way across the window at the moment]
> On 7/28/05 10:26 AM, "benducke at compuserve.de" <benducke at compuserve.de>
> wrote:
> > This sounds like the same bug you reported to me
> > some time ago.
> > tried to add this line:
> > #include <sys/types.h>
> > to every .c file that has:
> > #include /usr/include/sys/dirent.h
> > (make sure that types.h is included on a line
> > preceeding dirent.h)
> > This is a problem that often pops up on Mac mailing lists
> > and is to do with Apple shipping corrupt system header files.
> > I thought I had fixed this in the 0.95 release but obviously
> > not ...
> > As to why you get this problem on one machine and not on the other
> > I have no clue.
> > Cheers,
> > Benjamin
> > Datum: Mittwoch, 27. Juli 2005 0:40 am
> > Betreff: Gem compiling error
> >> Benjamin,
> >> I¹m a bit baffled. I had no problem compiling gem on myG5 desk.
> >> However,when I tried it on my G4 PowerBook it didn¹t work. I¹m
> >> sending the output
> >> below. Maybe you can shed some light before I start digging
> somewhat>> randomly.
> >> Both are running OSX 10.3.9 and (I think) have the same version of
> >> Developer¹s Tools (though there may be some difference I¹m not
> >> seeing).
> >> Thanks for your help.
> >> Michael
> >> ____________________
> >> C. Michael Barton, Professor of Anthropology
> >> School of Human Evolution and Social Change
> >> PO Box 872402
> >> Arizona State University
> >> Tempe, AZ  85287-2402
> >> USA
> >> Phone: 480-965-6262
> >> Fax: 480-965-7671
> >> www: <www.public.asu.edu/~cmbarton>
> >> - - - compile errors - - - -
> >> cmb-powerbook:~ cmbarton$ cd /downloads/gem-0.95
> >> cmb-powerbook:/downloads/gem-0.95 cmbarton$ make
> >> gcc  -c at_exit_funcs.c -Wall
> >> gcc  -c error.c -Wall
> >> gcc  -c tools.c -Wall
> >> gcc  -c reg_deps.c -Wall
> >> gcc  -c reg_entries.c -Wall
> >> /usr/include/sys/dirent.h:73: undefined type, found `u_int32_t'
> >> /usr/include/sys/dirent.h:74: undefined type, found `u_int16_t'
> >> /usr/include/sys/dirent.h:75: undefined type, found `u_int8_t'
> >> /usr/include/sys/dirent.h:76: undefined type, found `u_int8_t'
> >> cpp-precomp: warning: errors during smart preprocessing, retrying
> >> in basic
> >> mode
> >> In file included from /usr/include/dirent.h:64,
> >>                 from reg_entries.c:25:
> >> /usr/include/sys/dirent.h:73: parse error before "u_int32_t"
> >> /usr/include/sys/dirent.h:75: parse error before "d_type"
> >> /usr/include/sys/dirent.h:76: parse error before "d_namlen"
> >> /usr/include/sys/dirent.h:83: parse error before '}' token
> >> reg_entries.c: In function `restore_entries_gisman':
> >> reg_entries.c:650: dereferencing pointer to incomplete type
> >> reg_entries.c:652: dereferencing pointer to incomplete type
> >> reg_entries.c:702: dereferencing pointer to incomplete type
> >> reg_entries.c:703: dereferencing pointer to incomplete type
> >> make: *** [reg_entries.o] Error 1
> PO Box 872402
> USA
> Phone: 480-965-6262
> Fax: 480-965-7671
