[GRASS5] db.oodbfedit: a _very_ simplistic approach to dbf
attribute editing
Moritz Lennert
mlennert at club.worldonline.be
Sat Aug 6 17:03:32 EDT 2005
On Sat, August 6, 2005 2:20, Daniel Calvelo Aros said:
> He, he. No, that's not true anymore. What you have now is (test please, test
> please, test please):
> update table foo set bar=baz/2+1/(-4*toto);
> in addition to
> select * from foo where 1-(-4)/bar=2+baz
This seems to work perfectly, at least for the expressions I've tried.
> Furthermore, in http://grass.itc.it/pipermail/grass5/2005-June/018589.html I
> asked for testing an updated d.vect.thematic that handled (with the above
> patches in the parser) thematic mapping from expressions.
This also seems to work, after applying the following patch in v.univar.sh:
--- v.univar.sh 2005-08-06 21:35:38.814231960 +0200
+++ /usr/lib/grass/scripts/v.univar.sh 2005-08-06 22:26:33.626829856 +0200
@@ -131,7 +131,7 @@
gsub(" ","",expression);
split(col_list,vars,",");
for(i in vars){
- gsub(vars[i], "\$" i, expression);
+ gsub(vars[i], "$" i, expression);
if(expression~/\//){
theres_div=1;
With gawk the \$ is corrected automatically (but a warning is displayed), but
with mawk (debian's default awk) it fails. Without the \ everything seems to
work (again only rapid testing).
Thanks a lot Daniel: this makes both v.db.update and d.vect.thematic much more
useful !
Moritz
