[GRASS5] Re: [DebianGIS] problem building debian package from GRASS CVS source
Markus Neteler
neteler at itc.it
Mon Aug 8 14:08:33 EDT 2005
On Mon, Aug 08, 2005 at 01:36:55PM -0400, Steve Halasz wrote:
> On Mon, 2005-08-08 at 16:26 +0200, Markus Neteler wrote:
> > On Mon, Aug 08, 2005 at 04:17:21PM +0200, Moritz Lennert wrote:
> 8<------------snip-----------------
> > > One small point: In the config options defined in debian/rules one
> > > can find a --with-cxx on line 39 and a --without-cxx on line 51. Is
> > > there any good reason for this ? If not, any objections to removing
> > > the latter ?
> > I have removed --without-cxx in 6.1-CVS (I think that it should be
> > fixed in 6.0-debian as well).
> > The current 6.1-CVS contains a GCC4 patch for r.terraflow, the only C++
> > module.
> --without-cxx was originally added due to http://bugs.debian.org/287651,
> which had to do with insecure tempfile creation. Has that issue been
> resolved in r.terraflow?
> Steve
I don't know - does anyone in the list?
Markus
