[GRASS5] [bug #3469] (grass) about i.class
Brad Douglas
rez at touchofmadness.com
Mon Aug 8 18:22:47 EDT 2005
On Mon, 2005-08-08 at 15:29 +0100, Glynn Clements wrote:
> Brad Douglas wrote:
> > > this bug's URL: http://intevation.de/rt/webrt?serial_num=3469
> > > Subject: about i.class
> > > I am working with GRASS61, I try with i.class for supervised
> > > classification. After drawing the region on image I click to the
> > > Analyze region Menu, I get this error message
> > > WARNING:PREPARE_SIGNATURE: DATA ERROR (CLICK MOUSE TO CONTINUE). It
> > > seem that all the regions that I chose before now disappear. I try
> > > again with GRASS57, the result is also the same. Can you solve this
> > > problem for me? Thank you very much,
> > I traced this back to INAME_LEN being changed from 30 to 256 in
> > include/imagery.h.
> > This makes lib/vask/V_ques.c: V_ques() bomb out starting at line:
> > if ((length <= 0) || ((length + col) > 80)) ...
> > where the variable 'length' is passed in as INAME_LEN.
> > The program keeps running until it dies with a floating point exception.
> The attached patch changes V_ques() so that it truncates the length so
> that col + length <= 80 rather than returning an error. It also
> requires the starting column to be less than 80, rather than less than
> or equal to 80.
> The caller doesn't actually check the return value of V_ques(), and I
> suspect that this is quite common. Maybe V_ques() should just use
> G_fatal_error()?
I vote for applying Markus's quick-fix patch and filing a bug until a
more appropriate solution is developed (getting rid of vask?).
Brad Douglas <rez at touchofmadness.com>
