[GRASS5] R_line_width()
Tue Aug 9 10:57:11 EDT 2005
Huidae Cho wrote:
> I added 'int R_line_width(int width)' to the raster library. This
> changes line width for Draw_line().
The implementation in the PNG driver is massively inefficient (calls
acos() and tan() once per pixel). A more sensible approach would just
draw multiple, parallel single-pixel lines.
