[GRASS5] vector line thickness implemented - was Re: R_line_width()
Huidae Cho grass4u at gmail.com
Tue Aug 9 23:35:04 EDT 2005
Hi Michael,
The feature has been added to d.vect. Check out the latest CVS version
and you will find 'width=' option in d.vect help. It takes only integer
values since the value is the number of pixels itself on the monitor.
Enjoy ;-)
Huidae Cho
On Tue, Aug 09, 2005 at 08:22:50PM -0700, Michael Barton wrote:
> Markus,
> What is the command for line width. I looked in the on-line manual for GRASS
> 6.1 and couldn't find it. Maybe added too recently to show up? I'm happy to
> add it to the GIS Manager for vector display. Also is it an integer or can
> it take a decimal?
> Michael
> On 8/9/05 12:46 PM, "Markus Neteler" <neteler at itc.it> wrote:
> > Michael,
> > it *is* already in d.vect :-)
> > That's how I made the screenshot. Ready to test.
> > Markus
> > On Tue, Aug 09, 2005 at 11:13:07AM -0700, Michael Barton wrote:
> >> I'll second Markus. How do we add it to d.vect?
> >> Michael
> >> ______________________________
> >> Michael Barton, Professor of Anthropology
> >> School of Human Evolution and Social Change
> >> Arizona State University
> >> Tempe, AZ  85287-2402
> >> USA
> >> voice: 480-965-6262; fax: 480-965-7671
> >> www: http://www.public.asu.edu/~cmbarton
> >>> From: Markus Neteler <neteler at itc.it>
> >>> Date: Tue, 9 Aug 2005 11:00:37 +0200
> >>> To: Huidae Cho <grass4u at gmail.com>
> >>> Cc: <grass5 at grass.itc.it>
> >>> Subject: [GRASS5] vector line thickness implemented - was Re: R_line_width()
> >>> On Tue, Aug 09, 2005 at 01:35:48AM -0500, Huidae Cho wrote:
> >>>> Hi,
> >>>> I added 'int R_line_width(int width)' to the raster library. This
> >>>> changes line width for Draw_line().
> >>>> Huidae Cho
> >>> Hi Huidae,
> >>> this is ABSOLUTELY GREAT! I think we discussed it for years...
> >>> To all: find attached a small screenshot of d.vect using the
> >>> line width feature for the roads map.
> >>> Congratulations,
> >>>  Markus
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
