[GRASS5] v.in.ascii
Helena Mitasova hmitaso at unity.ncsu.edu
Wed Aug 10 12:21:10 EDT 2005
Thomas Adams wrote:
> What is the current status of v.in.ascii? There had been email exchanges
> about a bug and need for a fix. If there is a fix what do I need to do
> to implement it?
v.in.ascii should work without problems for smaller data sets (by that I
mean around 500000 points) and in fact with the latest release it should
work up to about 3 million points. We are now testing how far we can get
if we skip the topology building - it seems to be working for larger
data sets but becuase every v* command expects the topology to be built
(although it may not always be needed for point data) more changes need
to be done (or V_build needs to be changed to free the memory as Radim
and Hamish indicated - that has not been implemented).
Let me know if you need to work with millions of points, otherwise
v.in.ascii should be fine in the new release,
Helena
> Regards,
> Tom
