[GRASS5] d.vect.thematic wish: handle null values
Moritz Lennert
mlennert at club.worldonline.be
Thu Aug 11 17:20:00 EDT 2005
Trying to make maps with d.vect.thematic I have stumbled upon the problem that
the module fails when there are null values in the table (postgresql):
awk: (FILENAME=- FNR=1) fatal: division by zero attempted
Thematic map legend for column revmed of map ssbxl01
Value range: - 33079
Mapped by 7 intervals of
Color(R:G:B) Value
0:0:250 7 -
DBMI-Postgres driver error:
Cannot select:
SELECT cat FROM ssbxl01 WHERE revmed >= 7 and revmed<=
ERREUR: L'opérateur n'existe pas : integer <=
HINT: Aucun opérateur correspond au nom donné et aux types d'arguments. Vous
devez ajouter des conversions explicites de type.
35:0:215 -
Cannot select:
SELECT cat FROM ssbxl01 WHERE revmed > and revmed<=
ERREUR: syntax error sur ou près de «and» at character 41
etc...
Now I can see two theoretical solutions to this:
1) handle null values
2) allow to give a value that represents null values (e.g. -99999)
For both of these solutions, d.vect.thematic should offer the choice of a
color for these values, so that they do not use the same color scheme as the
'valid' values.
Moritz
