[GRASS5] [bug #3514] (grass) r.surf.contour - dozens of warnings
Glynn Clements
glynn at gclements.plus.com
Fri Aug 12 11:37:16 EDT 2005
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3514
> Subject: r.surf.contour - dozens of warnings
> GRASS 6.1.cvs (caves_utm33):~ > r.surf.contour input=melio_poz_clear_rast output=melio_poz_clear_rast_10_dem2
> WARNING: segment_pagein: No such file or directory
> Although it completes, looks scarry. What is it?
if (read (SEG->fd, SEG->scb[cur].buf, SEG->size) != SEG->size)
G_warning ("segment_pagein: %s\n", strerror(errno));
return -1;
The warning occurs if read() returns a short count, i.e. if you try to
read beyond the end of the file, or an error.
The actual error message is bogus; read() only sets errno if it
returns a negative result, not if it returns a short count.
