[GRASS5] Oddity: r3.null
Sat Aug 13 11:35:06 EDT 2005
Brad Douglas wrote:
> I recently added -Werror-implicit-function-declaration to my compiler
> flags to identify source that needs 'upgrading' and function
> declarations.
> While making changes to r3.null (null_main.c), I noticed the following
> code:
> if (G3d_isNullValueNum (&value, G3D_DOUBLE)) {
>     if (modifyNull) {
>         value = newNullVal;
> modifyNull is actually a void function with a number of parameters, so
> the truth statement is always true, testing for the existence of the
> function?
> Can someone direct me as to what the purpose of this is?  An
> evolutionary relic?  Any help is greatly appreciated.
I suspect that it should refer to changeNull instead.
