[GRASS5] lib/vector/rtree/split_l.[c|h]
Radim Blazek
radim.blazek at gmail.com
Mon Aug 22 08:51:42 EDT 2005
On 8/22/05, Brad Douglas <rez at touchofmadness.com> wrote:
> On Mon, 2005-08-22 at 12:00 +0200, Radim Blazek wrote:
> > On 8/21/05, Markus Neteler <neteler at itc.it> wrote:
> > > On Sat, Aug 20, 2005 at 11:25:31PM -0700, Brad Douglas wrote:
> > > > Is it okay if I remove split_l.[c|h] from lib/vector/rtree and it's
> > > > Makefile? They are unused and essentially duplicated in split_q.[c|h].
> > > > IMHO, it's clutter that serves as obfuscation.
> > > It should be ok (and it doesn't get lost in CVS).
> > > Markus
> > I would prefer to keep it in CVS, split_l and split_q implement 2 methods
> > for node splitting and I had not time to think/test both in GRASS.
> > If we leave it there, hopefully someone can compare both with real data.
> > Look also in MAILS:
> > | regarding split_l.c vs. split_q.c: these involve a choice you can make between
> > | speed and box optimization. you should use the quadratic version ('q') if it's
> > | fast enough for your needs, and use the less expensive linear method
> > if not. note
> > | that in both cases various branches of the resulting rectangle trees
> > may overlap.
> > | there's another version of the technique called "R+ Trees" which guarantees no
> > | overlaps, but i don't have an implementation of that version. i
> > believe it's even
> > | slower than either r-tree splitting method, so you should probably
> > also take all
> > | of that into account.
> I saw that in MAILS, but I was under the assumption that computers were
> now sufficiently fast as not to generate much overhead. It has been
> three years since MAILS was authored.
> Do we have timing differences between the two methods? How much extra
> overhead are we talking? Seconds? Minutes?
> Can we make this an option in the configure script to define a wrapper
> macro? As of now, few people knows the different methods exist and even
> fewer are going to do the nasty coding to make them work.
> I have already deleted them, but they can be easily brought back. I
> would just like to have a good reason to do so.
OK.
Notes on spatial index:
There are problems with space occupied by spatial index but I don't
know how much it depends on splitting method used.
It would be also interesting to experiment with MAXCARD.
Also dimension should be changed dynamicaly (currently 3D).
Radim
