[GRASS5] d.legend crash (R_*() related?)
Markus Neteler neteler at itc.it
Tue Aug 23 05:09:52 EDT 2005
On Mon, Aug 22, 2005 at 08:21:58PM -0700, Brad Douglas wrote:
> On Mon, 2005-08-22 at 21:43 +0200, Markus Neteler wrote:
> > On Mon, Aug 22, 2005 at 11:59:54AM -0700, Brad Douglas wrote:
> > > On Mon, 2005-08-22 at 16:38 +0200, Markus Neteler wrote:
> > > > The d.legend/d.rast.leg worked last week - may it be related to recent R_() changes?
> > > > d.legend works fine if I don't use d.font.freetype.
> > > > Actually I don't know how to debug this as d.legend apparently crashes in the
> > > > very first line.
> > > Markus,
> > > Could this be a 64bit issue?  I just updated my i686 machine and I'm
> > > unable to replicate the problem.
> > maybe yes. But I used it successfully on the same machine last week.
> > I'll try again tomorrow (at home now). Maybe Huidae has an idea as well.
> I had made some very minor changes over the weekend, but I temporarily
> backed most of them out and recompiled with no success.
I have sort of located the problem:
I did:
d.mon x0
d.font.freetype font=/usr/X11R6/lib/X11/fonts/TTF/luxirr.ttf
d.legend evi_regress_4_6_2001.slope
*** glibc detected *** double free or corruption (out): 0x00000000005460f0 ***
ERROR eof from graphics driver.
In d.legend it crashes in D_add_to_list():
        if(!use_mouse)
            D_add_to_list(G_recreate_command()) ;
which goes to
int D_add_to_list( char *string)
        return(R_pad_append_item("list", string, 0)) ;
which goes to
Breakpoint 11, R_pad_append_item (item=0x2a9555e90e "list", value=0x52afa0 "d.legend map=\"evi_regress_4_6_2001.slope\" color=\"black\" lines=0 thin=1 labelnum=5", replace=0) at item_appnd.c:13
int R_pad_append_item ( char *item, char *value, int replace)
    char result;
    _hold_signals(1);
    _send_ident (PAD_APPEND_ITEM);
    _send_text (item);
    _send_text (value);
    _send_int (&replace);
    _get_char (&result);        <-- WOM!
    _hold_signals(0);
    return result;
in details the _get_char() function:
... where achar="list" when crashing in lib/raster/io.c:
int
_get_char(char *achar)
    flushout() ;                <- Monitor <x0>: Premature EOF
    _get (achar, 1);
    return 0;
Basically the flushout() is killing the monitor after using d.font.freetype.
Maybe something needs to be added to d.font.freetype due to the recent
R_*() or XDRIVER changes?
Any ideas?
 Markus
