[GRASS5] str*() vs strn*() functions
Paul Kelly paul-grass at stjohnspoint.co.uk
Fri Aug 26 05:18:40 EDT 2005
Hello Brad
On Fri, 26 Aug 2005, Brad Douglas wrote:
> Is there any particular reason there has been a recent move from using
> strn*() function to using str*() functions?
It was a bugfix: with strncmp it was returning a match if one string was
shorter than the other but matched the first n characters. We needed to
match the whole string.
> Specifying the string length has security benefits.
What is the problem with using strcmp specifically?
I had a think about it and couldn't think of any reason not to use strcmp(),
so I changed some occurences of strncmp() I had added in the past (blindly
following the way it was done in other parts of the proj library).
Paul
