[GRASS5] [bug #3573] (grass) v.db.select - don't force all the input columns to the output datable
Markus Neteler
neteler at itc.it
Fri Aug 26 06:14:01 EDT 2005
On Thu, Aug 25, 2005 at 02:40:31PM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3573
> Subject: v.db.select - don't force all the input columns to the output datable
> Platform: GNU/Linux/i386
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: cvs 23.08.05
> Please let me choose whether I want all the input columns to be present in the output datatable or only those selected by me.
> Below I'm trying to omit importing the x and y columns to output datatable (I want to use them only for coordinates). But this is recognized as an "error".
> v.db.select -c map=wejscie column=cat,rast_val,x,y | v.in.ascii output=grd_faults_pt_nocat_addcat_asc columns='CAT integer, WYS double' x=3 y=4 cat=1
> Maximum input row length: 44
> Maximum number of columns: 4
> Minimum number of columns: 4
> column: 1 type: integer
> column: 2 type: double
> column: 3 type: double
> column: 4 type: double
> ERROR: Number of columns defined (2) does not match number of columns (4)
> in input.
> Maciek
> -------------------------------------------- Managed by Request Tracker
Maciek,
you could put a
| cut -d'<delimiter>' -f<field>[,<field>] in between.
Markus
