[GRASS5] str*() vs strn*() functions
Fri Aug 26 21:14:33 EDT 2005
Brad Douglas wrote:
> > > Specifying the string length has security benefits.
> > What is the problem with using strcmp specifically?
> Buffer overflow attacks.
I think you're getting confused with strcpy/strncpy. strcmp only reads
the strings, it doesn't write anything so it can't cause a buffer
overflow.
