[GRASS5] [bug #3587] (grass) v.to.rast: assign a proper color table to the output
Markus Neteler
neteler at itc.it
Tue Aug 30 06:14:59 EDT 2005
On Mon, Aug 29, 2005 at 10:40:44AM -0400, Helena Mitasova wrote:
> Markus Neteler via RT wrote:
> >Related to the v.to.rast color table problem there might
> >be below code in:
> >vector/v.to.rast/support.c
> >int
> >update_fcolors (char *raster_name)
> > struct Colors colors;
> > /* G_read_fp_range(raster_name, G_mapset(), &range); */
> > /* G_get_fp_range_min_max(&range, &min, &max); */
> > G_make_rainbow_colors(&colors, 0, 360);
> > G_write_colors(raster_name, G_mapset(), &colors);
> > return 0;
> >Should it be min max instead of 0 360?
> yes, I am guessing that this color table was there for v.to.rast2 for
> the line direction angle - min,max should cover it.
I have update v.to.rast to use min/max instead of 0..360
for floating point maps for the rainbow color table.
Also updated:
- rainbow instead of random colors for integer maps (for consistency).
- description [1]
Markus
[1] If developers update a module, please also update the description.html...
Hot candidates: the SQL related pages
