[GRASS5] raster category confusion
Wed Aug 31 16:05:02 EDT 2005
Markus Neteler wrote:
> > > > Do you have some other mapset in the search path ahead of the current
> > > > mapset?
> > > GRASS 6.1.cvs (spearfish60):/hardmnt/thuille0/ssi/grassdata/spearfish60 > g.mapsets -p
> > > neteler PERMANENT user1
> > > It seems that there is only this single map gives wrong results.
> > > It's a 32bit RHEL4 box.
> > The only thing I can suggest is using a debugger.
> To recall, the problem:
> r.mapcalc "one=1"
> r.cats one
> Reading one in neteler ... 100%
> 99
> 100
> 120
> 156
Forget about r.cats (and categories in general). This:
> r.stats -1 one
> 120
> 156
> 99
> 100
> 120
> 156
> 99
> 100
is a lot more interesting (and relevant).
