[GRASS5] [bug #3876] (grass) g.proj: proj4= fails, wkt= works partialy
Request Tracker
grass-bugs at intevation.de
Sat Dec 3 15:38:33 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3876
Subject: g.proj: proj4= fails, wkt= works partialy
Platform: GNU/Linux/i386
GRASS Version: CVS 2005-11-16
Here is my initial projection:
GRASS 6.1.cvs (huha2):~ > g.proj -p
-PROJ_INFO-------------------------------------------------
datum : S-42
towgs84 : 33.4,-146.6,-76.3,-0.359,-0.053,0.844,-0.84
proj : ll
ellps : krassovsky
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
I wanted to change it with "g.proj wkt=wkt_file". It kindoff works, but:
1. the PERMANENT/WIND and PERMANENT/DEFAULT_WIND are left unchanged (still refer to latlong).
2. only the WIND in working mapset is changed properly
3. surprisingly, a correct DEFAULT_WIND appears in current working mapset - but it should go to PERMANENT.
Trying to change a projection to a following PROJ.4 description:
GRASS 6.1.cvs (huha2):~ > cat puwg1965_IV.prf
+proj=sterea +lat_0=50.625 +lon_0=21.08333333333333 +k=0.9998 +x_0=4637000 +y_0=5467000 +ellps=krass +towgs84=33.4297,-146.5746,-76.2865,-0.35867,-0.05283,0.84354,-0.84077 +units=m
It fails, no change is done:
GRASS 6.1.cvs (huha2):~ > g.proj -c proj4=puwg1965_IV.prf
WARNING! A projection file already exists for this location
This file contains all the parameters for the
location's projection: ll
Overriding this information implies that the old projection parameters
were incorrect. If you change the parameters, all existing data will be
interpreted differently by the projection software.
GRASS will not re-project your data automatically
Would you still like to overwrite the current projection information (y/n) [n] yProjection information updated!
datum : S-42
proj : ll
ellps : krassovsky
unit : degree
units : degrees
meters : 1.0
Maciek
-------------------------------------------- Managed by Request Tracker
